Easier way to position figures in scenes?
Hi everyone, at the moment I set up my setting, eg PW Caribbean Island. which is a large landscape. I choose a camera. Then I add my figure to the scene (eg Unicorn for DAZ Horse 2). But to find the figure, I have to go out and out and out on the scene, over and over, till eventually I see the bounding box of the figure. Then I have to use translations to go back in, in, in on the scene, till the figure is visible in front of the camera I have chosen. Is there an easier way to find the figure and put it where it belongs and return to the camera I chose? Like, attaching it to the camera, or...? Thanks!
  • Alt+Drag from the library. However, note that Iray has floating point rounding issues far from the origin, so you should try to centre the part of the set you are using close to the scene centre anyway.
  • In addition to the above, if you have items that are already loaded and you want to bring them into view you can use the mcjComeHere script.
  • Thanks, to you both - but neither idea is working for me. Re the distance with the mj script, how do I know what distance to put into the slider? Sorry to be so dim; I have tried various distances, no joy. Maybe I should dump the PW Caribbean island idea, LOL!
  • Oh wait, I unticked the translate lock slider and it has worked! Yaay! Thanks so much! :D
  • FirstBastionFirstBastion Posts: 8,085
    edited September 2023
    This is how I do it.
    If you have a camera selected,  you can see its XYZ position in the parameters tab.
    Simply add those 3 numbers to your translations for the character figure and it will move to the camera position.  Then you can fine tune the positioning from there. Takes about 10-15 seconds.
    Ahh! Thanks so much! :D
  • I tend to place the figure and then move the scene around it.
  • FirstBastion's suggestion works well. Adding to it ... another option is to add several cameras to the scene in strategic locations looking in important directions. After these are set up, you can just choose a camera view to either find your subject and/or then move it.
  • Thanks everyone, all helpful! :)
  • TimbalesTimbales Posts: 2,457
    You can also use the align tool. In Select the camera, then the figure. Align to centers to centers on all axis and it will bring it to the camera. Then you can place and adjust position as needed.
  • Ooh, I Am learning so much - thank you! :)
    Thank you for this! I've often used the XYZ translations for a model in the scene that is already where I want a model to be but this seems much faster.
  • mwokeemwokee Posts: 1,275
    No one will like my answer but I create scenes and characters separately and merge together in Photshop. Faster and easier for me plus I have greater control with post processing. See? Tolja no one would like this.
  • CybersoxCybersox Posts: 10,025
    Nope, I do the same thing sometimes.  There's a lot of stuff that's simply easier and more effective to do in PS, especially when it comes to large numbers of figures/elements.
