How to delete a surface in an imported object? [w/ screenshot]
PA_ThePhilosopherPA_ThePhilosopher Posts: 1,039
Hey guys,
I have an object file of an altar which I got from the google/sketchup database. As you can see in the screenshot below, this object has multiple surfaces. What I would like to do is to delete some surfaces (for example, I want to delete the human figure, the book + stand, etc.). Is there a way to individually delete these items within the single object?
Thanks!
1350 x 954 - 410K
Post edited by PA_ThePhilosopher on
    You are not actually wanting to delete surfaces...you are wanting to delete actual geometry.
    So, open the Geometry Editor tool and select the item in the Scene tab/pane.  Then right click in the viewport and then Geometry Selection > Select By > Surface (if you know the surface names, and for the person, at least 3 are visible in your screenshot).  This will highligh the chosen surface, if it's what you want to get rid of then right click and choose Geometry Visibility > Hide selected polygons.  Then to make it permanent right click > Geometry Editing > Delete Hidden Polygons.  After you've delete what you want, export and reimport the item.
  • PA_ThePhilosopherPA_ThePhilosopher Posts: 1,039
    edited October 2015
    You have been incredibly helpful. Thank you. Do you also know, once the geometry is deleted, is there a way to remove their properties in the surface editor  (on the right side in screenshot)? Or perhaps that is why you need to export and re-import the object?
    Thanks again.
    Save it out as a prop asset, then load that or export and reimport it...the reloaded item will not have those included in it.
  • Perfect, thank you. And I am assuming, in order to apply iRay shaders (such as gold plating to candle sticks), these sketchup objects first need to be UV mapped.... And, to do this, I would need to separate out each individual obect as a separate .obj file, correct?....Unless.... I can UV map the entire object as a whole...
    I cannot tell you how appreciative I am.
    Yes, they need to be UV mapped...and yes you can to the whole thing at once, but it would be 'cleaner'/better to break it up into individual items.
  • prixatprixat Posts: 1,627
    If you've got all those surfaces showing up in Studio, isn't it already UV mapped?
