full screen mode can't get out
I have daz 4.8 How do you get out of full screen mode? The Esc key does not work. The only way I have found to get out of full screen mode is to close daz
any one know how to get out of full screen mode without closeing daz
Thanks
  • IceCrMnIceCrMn Posts: 2,334
    Press F3 to open the workspace Customize settings panel.
    On the left side of the pane scroll down to "Window" and expand it.Check to see what the keyboard shortcut is.If there isn't one you can right click it and select "Change Keyboard Shortcut" , at this point you press a key on the keyboard you want to use for full screen mode,most times it's set to F11 .
  • fixmypcmikefixmypcmike Posts: 19,735
    Shift-F11, the same way you get in.
  • Thanks icecrmm there was no shortcut so I did what you sad and made one now it works thanks again.
    You're welcome :)
