Log warnings of files not found in Daz Studio, yet show installed and Metadata Issue
Hello,
On my MacBook Pro M1, back in the spring I was updating metadata on the Beta at the time, now on 4.21.1.80, when it crashed. This is the primary version I use of DAZ Studio. After updating today's purchases and saving my work I checked my Public Release version, 4.21.0.5 to see if it reflected the updates I had made to the metadata, and it had. One older file had everything dumped into General and I had sorted them into Enviroments, Props, Funishings... I saved that as well. The crash also brought back all the bogus 'Lost and Found' lines inserted into the metadata by Daz, where otherwise correct data was there. I used to be able to delete it. I can still do it on my other computers, Win10 Betas.
It got me to wondering if I could copy my saved 4.21.0.5 as the Support files for 4.21.1.80 and maybe the Beta would clear out all the Lost and Found files I had cleaned up before that one crash and which I can't fix now. I always install with DIM, never turn on DAZ Connect, and I verified that all my CMS and file structures match in DIM and DAZ Studio.
But I also compared both logs for each version and I found some similar warnings:
2023-09-19 12:47:53.549 [WARNING] :: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(369): Iray [WARNING] - LINK:PLUGIN :: 0.0 LINK plug warn : Loading /Applications/DAZ 3D/DAZ 3D/DAZStudio4 64-bit/libs/iray/ffmpeg_video_decoder.so: dlopen(/Applications/DAZ 3D/DAZ 3D/DAZStudio4 64-bit/libs/iray/ffmpeg_video_decoder.so, 0x0001): Library not loaded: @executable_path/libavutil.56.dylib
2023-09-19 12:47:53.549 [WARNING] :: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(369): Iray [WARNING] - LINK:PLUGIN :: 0.0 LINK plug warn : Referenced from: <8171360D-13FB-37A1-AC01-06996946A556> /Applications/DAZ 3D/DAZ 3D/DAZStudio4 64-bit/libs/iray/libavcodec.58.dylib
2023-09-19 12:47:53.549 [WARNING] :: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(369): Iray [WARNING] - LINK:PLUGIN :: 0.0 LINK plug warn : Reason: tried: '/Applications/DAZ 3D/DAZ 3D/DAZStudio4 64-bit/DAZStudio.app/Contents/MacOS/libavutil.56.dylib' (no such file), '/usr/local/lib/libavutil.56.dylib' (no such file), '/usr/lib/libavutil.56.dylib' (no such file, not in dyld cache)Library not loaded: @executable_path/libavcodec.58.dylib
2023-09-19 12:47:53.549 [WARNING] :: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(369): Iray [WARNING] - LINK:PLUGIN :: 0.0 LINK plug warn : Referenced from: <A945A99D-5D49-3CE6-966A-917EA4C84C37> /Applications/DAZ 3D/DAZ 3D/DAZStudio4 64-bit/libs/iray/libavformat.58.dylib
2023-09-19 12:47:53.549 [WARNING] :: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(369): Iray [WARNING] - LINK:PLUGIN :: 0.0 LINK plug warn : Reason: tried: '/Applications/DAZ 3D/DAZ 3D/DAZStudio4 64-bit/DAZStudio.app/Contents/MacOS/libavcodec.58.dylib' (no such file), '/usr/local/lib/libavcodec.58.dylib' (no such file), '/usr/lib/libavcodec.58.dylib' (no such file, not in dyld cache)Library not loaded: @executable_path/libavutil.56.dylib
2023-09-19 12:47:53.549 [WARNING] :: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(369): Iray [WARNING] - LINK:PLUGIN :: 0.0 LINK plug warn : Referenced from: <CCB2D1CA-2DA6-3726-97C9-4F9DD9B99A0F> /Applications/DAZ 3D/DAZ 3D/DAZStudio4 64-bit/libs/iray/libswscale.5.dylib
I have checked the file locations and they are where they are supposed to be. Also, DIM shows they are installed.
But I am getting these additional warnings:
2023-09-19 12:47:53.577 [WARNING] :: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(369): Iray [ERROR] - PLUG:PLUGIN :: 0.0 PLUG plug error: Library /Applications/DAZ 3D/DAZ 3D/DAZStudio4 64-bit/libs/iray/libnvindex.so: symbol "mi_plugin_factory" not found.
2023-09-19 12:47:53.584 Iray [INFO] - PLUG:PLUGIN :: 0.0 PLUG plug info : Loaded library "/Applications/DAZ 3D/DAZ 3D/DAZStudio4 64-bit/libs/iray/libnvindex_application_layer_application_layer.so".
2023-09-19 12:47:53.584 [WARNING] :: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(369): Iray [ERROR] - PLUG:PLUGIN :: 0.0 PLUG plug error: Library /Applications/DAZ 3D/DAZ 3D/DAZStudio4 64-bit/libs/iray/libnvindex_application_layer_application_layer.so: symbol "mi_plugin_factory" not found.
2023-09-19 12:47:53.597 Iray [INFO] - PLUG:PLUGIN :: 0.0 PLUG plug info : Loaded library "/Applications/DAZ 3D/DAZ 3D/DAZStudio4 64-bit/libs/iray/libnvindex_plugin_openvdb_integration.so".
2023-09-19 12:47:53.597 [WARNING] :: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(369): Iray [ERROR] - PLUG:PLUGIN :: 0.0 PLUG plug error: Library /Applications/DAZ 3D/DAZ 3D/DAZStudio4 64-bit/libs/iray/libnvindex_plugin_openvdb_integration.so: symbol "mi_plugin_factory" not found.
And for these plugin which I am not sure are related:
2023-09-19 12:47:54.357 [WARNING] :: Object::connect: No such slot ABFluidosCompanionAction::handleInterfaceColorsChanged() in /Volumes/HDD/Sources/DAZStudio4.5+SDK/samples/interface/FluidosCompanion/abFluidosCompanion.cpp:57
2023-09-19 12:47:54.357 [WARNING] :: Object::connect: (sender name: 'Style')
2023-09-19 12:47:54.357 [WARNING] :: Object::connect: (receiver name: 'EditAction')
2023-09-19 12:47:54.391 [INFO] :: Creating Pane Manager...
2023-09-19 12:47:55.644 [INFO] :: Successfully created OpenGL viewport for AuxViewportView.
2023-09-19 12:47:55.913 [WARNING] :: QFile::flush: No file engine. Is IODevice open?
2023-09-19 12:47:56.181 [WARNING] :: QLayout: Cannot add null widget to QGridLayout/
2023-09-19 12:47:56.201 [WARNING] :: Object::connect: No such slot ABFisioPane::deleteKeyframes()
2023-09-19 12:47:56.201 [WARNING] :: Object::connect: (sender name: 'StyleBtn')
2023-09-19 12:47:56.201 [WARNING] :: Object::connect: (receiver name: 'Fisio')
I tried uninstalling the plug-ins and refreshing the data, then re-installing them and the log shows the same errors.
If anyone has any help to offer, understanding I am not a programmer, and I will need guidance for a MacOS and a lot of patience I would deeply appreciate it. I opened a technical work order with Daz at the time and it has never been responded to.
Thank you,
Mary
