Utility to compare surface settings?
Does anyone know if there's a utility that can be used to compare similar surfaces? For example, if you're trying to track down the surface setting differences between the arms and legs on a figure? I know of an extreme method that works but is overkill for a quick check.
  • felisfelis Posts: 6,609
    I don't know of a utility.
    But if you select more surfaces, e.g arms and legs, then values that differentiates will be marked with a question mark.
