Soiree Glam Hair and Ponytail for Genesis 8 and 8.1 Females Dforce Hair Troubles
bashtonbashton Posts: 10
I got this hair, and overall it's a pretty good product, however the dforce is misbehaving. Has anybody else got this hair and is having the same kind of trouble? I've tried everything that I can think of and half of the hair (best case scenario) just gravitates toward the character. The simulation on the image was all at default settings.
969 x 881 - 558K
  • crosswindcrosswind Posts: 10,347
    Yes..  you may try these:
    - For this pose, the value of Collision Offset on the dynamic surface is too high, change it to 0.03 or lower. Add some values to Velocity Smoothing / Velocity Smoothing Iterations: 0.6 / 4
    - There was weight painted on the ponytail with a dForce Modifier Weight Node but not optimal. Add weight node back to it and repaint / smooth the weight.
    - Tweak the bones rotation near the root of ponytail if needed.
    1771 x 1396 - 382K
  • Moved to Technical Help as it is not a Daz Studio application question.
    Collision offset. That's the ticket! The specific pose was unimportant. It's just that the hair wouldn't fall naturally no matter what. All better now! Thanks!
