ATTN: G9 UNBM users, an issue with bends and solution!
UNBM
For those that are experiencing horrible bend issues with the G9 UNBM, specifically the leg side bend, it is caused by the following morphs that may, or may not be conflicting with Daz's own corrective morphs, I didn't test it due to me removing these morphs and I'm not going to go through the hassle of reenabling them just yet:
  • pJCMkh9fThB-85S35L
  • pJCMkh9fThB-85S-35R
  • pJCMkh9fThB-85S70L
  • pJCMkh9fThB-85S-70R
  • pJCMkh9fThB-115S35L
  • pJCMkh9fThB-115S-35R
  • pJCMkh9fThB-115S70L
  • pJCMkh9fThB-115S-70R
You can find these files here: => \data\DAZ 3D\Genesis 9\Base\Morphs\K.H. Image Studio\UNBM for Genesis 9 Feminine Base
I backed them up, and moved them to a backup folder on another drive for easy reference, as I'm not going to remember those names offhand, particularly for when I re-install the pose pack in the future, that way I know from a glance which files to remove, but the point being, that you must remove those files from the data folder in order for them to no longer load.
I really despise workarounds as more often than not they end up replacing official solutions, but this will work best until there's an official solution.
  • barbultbarbult Posts: 27,641
    Daz doesn't uses the "JCM" or "pJCM" nomenclature for corrective morphs on Genesis 9. The new terminology is "cbs". So, it seems unlikely that it is a name conflict with a Daz 3D created morph. I also wonder why a PA is not following the proper new naming convention for Genesis 9 corrective morphs, and why Daz QA accepted that. Does the UNBM bend  distortion happen on a base Genesis 9 or just a morphed character? I don't own the product to try it.
  • takezo_3001takezo_3001 Posts: 2,044
    edited September 2023
    The base G9 with no other morphs, I would have posted a pic, but I already moved the morph, but I can put the morphs back and test it and provide pics to illustrate the issue clearly, so watch this post until then...
    EDIT: I did not consider the name conventions, so nice catch, and no, it does not conflict with anything, as I un/reinstalled both G9 and her accesories/morphs and every other corrective morph pack, and yeah, it seems like it's by design, so maybe it's an oversight.
    1581 x 590 - 167K
    Post edited by takezo_3001 on
  • crosswindcrosswind Posts: 10,347
    Hmm... the PA should've followed the new naming convention though I personally still prefer to '..jcm...'   You're right. More likely these corrective morphs are meant to fix the combo poses for thighs Bend + Side-Side with certain degrees... but the controllers were wrongly set up.
    It seems not an oversight as the setup is not complicated...anyway pls submit a support ticket.
    Post edited by crosswind on
  • Yeah, I may just do that, as the morphs are really jarring, I may also replace the morphs with ones of my own!
    Ye, certainly you may, and they could be even better than the ones from the product.devil
