Been away awhile and I forgot how to do this
Knight22179
Been away from Daz Studio for a while. Got a new PC and re-installed Daz Studio.
But I forgot how to install Gen-X apprently, because it's not showing up within the program.
Edited to add: Keep in mind, I got Gen4 on Renderosity so I bought the upgrade to Gen-X here
Can someone please help? Thanks
Post edited by Knight22179 on
When you run the installer(s), watch to see what path it says it is going to install into and make sure that's the correct one, and isn't somehow going into some other folder, perhaps from an older or a beta version of DAZ studio. I installed mine manually, but if you are using DIM, presumably you could also have accidentally set DIM up to install into the wrong spot as well.
Of course make sure to enter your serial number in DAZ studio to enable it too.
And just so there's no confusion, when you say "it's not showing up within the program", what exactly you looking for? Is the pane missing, or you can't see it in the list of plugins, etc.
