Copying translation params from one character to another
andya_b341b7c5f5andya_b341b7c5f5 Posts: 694
edited October 2015 in New Users
Hopefully there is a simple answer to this - it seems to me there should be.
What I want to do is load a character (A), which I have saved as a scene subset, into an existing scene, so with the scene open I select character A and merge it into the scene.  So far so good.  But the camera(s) are pointing at another character (B), and A loads out of shot.  I want to move A to the same point as B to get it into shot.  With B selected in the scene tab, I highlight  Translation in the Parameters tab, and hit Ctrl-C to copy.  I then highlight A in the scene tab, select Translation again in the Parameters tab and hit Ctrl-V to paste.  Although this does paste the translation params from B to A, and hence A moves to the same location as B (fine), it also copies a slew of other params from B to A, including numerous morph values thus changing the shape etc. of character A. Clearly this is not what I want.
Is there a way to copy only the translation params from one character to another, or do I have to manually enter the same values for A as B has?
Post edited by andya_b341b7c5f5 on
  • Richard HaseltineRichard Haseltine Posts: 111,217
    edited October 2015
    Edit>Paste does allow some finer control, but it may be simplest to paste to a primitive (Create>New Primitive), then copy from that and paste to B.
  • OstadanOstadan Posts: 1,133
    The Align tab can bring many things at once to the same coordinates.   It's probably one of those handy tools that isn't well-known enough.
  • Thanks for the suggestions.  Using a primitve (or maybe a null?) as a proxy is ingenious.  I have not come across the Align tab but will look into it.
