Suddenly Iray doesnt work anymore
JamesJames Posts: 1,191
edited September 2023 in Daz Studio Discussion
Even with no scene and only G9 on the viewport, iray doesn't work nomore.
Can't render either.
My GPU is 4070ti.
2023-09-05 15:42:29.731 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: Cannot render: found no usable devices. Please update your NVIDIA driver (www.nvidia.com) to at least 471.41, or enable CPU-only rendering.
2023-09-05 15:42:29.731 [ERROR] Iray :: Invalid parameters (NULL pointer).
2023-09-05 15:42:29.789 [INFO] :: Saved image: C:\Users\USER\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
2023-09-05 15:42:29.793 [INFO] :: Finished Rendering
2023-09-05 15:42:29.818 [INFO] :: Total Rendering Time: 2.46 seconds
The log says can't find usable device??
What to do?
Post edited by James on
  • LeanaLeana Posts: 13,565
    As the log says, update your GPU drivers.
    If it has been working before, are you allowing Windows to update your GPU drivers? The ones Windows is 'updating' to are not compatible.
    This is the one and only place one should use for Nvidia drivers; https://www.nvidia.com/Download/index.aspx
  • JamesJames Posts: 1,191
    I've updated the driver to the latest through Geforce Experience.
    But no luck
    Currently I switch to the DAZ3d public build version, it can do the iray.
    My iray dead again.
    I think it happened when I put my computer on sleep mode, when awaked, it didn't awake instead restarting, after that I can't do iray on public build version too.
    Never mind,
    It's alive again for both version.
    I don't know what's going on
    It stops again.
    Does anyone has any idea, what could be wrong?
    I have reisntalled the VGA driver. 536.99
    Okay, hopefully I've fixed the problem.
    It seems, the newest NVIDIA driver doesn't work well with DAZ3d.
    So I installed an older driver 531.61 studio driver.
    and  the iray preview and render works again.
