How to a export prop edited in geometry.
Hope369
in The Commons
How can I save and export a prop I edited in the geometry editor? By that, I mean to also import that same prop with shader parts and all.
If you mean to use it in other software, go to File > Export > set OBJ file format.
However, that does not export all the shader settings. Only in Daz Studio you can get all the particolars of a Daz Studio shader.
If you want to save your prop so you can use it in other Daz Studio scenes, best thing is to save it to the library:
File > Save As > Support Asset > Figure/Prop Asset
Then fill in the dialogue.
If you're talking about saving the edited version as something you can reuse in Daz you can do one of two things:
