What is an "Avatar" node, can I create one?
Vholf3D
Filament renderer has this "Draw Avatars" option where certain things like cameras, guides, nulls and other objects are shown/hidden. Is there a way to create or tag an object as an avatar so that they behave the same way?
Basically I would like to create some helper objects, (with geometry, nulls wont do) that will behave the same way.
Thanks.
Try the various Visiblen In options in the Parameters pane, though that is not Drawstyle-dependent.
Thank you but I want to create an actual Avatar Node, if possible, one that is Drawstyle-dependent.
Measure metrics has this helper nodes that are indeed avatars and have a custom shape, so I assume it is indeed possible.
