Help,Daz studio's wireframe view mode don't view anything
Help,Daz studio's wireframe view mode don't view anything.
Post edited by peter11456_17cbb10b5f on
You are not giving much information here?
There are several Wire Frame views, which one are you using, and how are you selecting it? What are you trying to view in wire frame mode?
I select it in the viewport window, and then the model disappear.
You still don't say which one you are using?
If you are using 'Wire Bounding Box' then there is very little to see, have you tried 'Wireframe' it should show as white lines. If you are not seeing that, are your graphic card drivers up to date, as the Viewport uses OpenGL, and the drivers need to be current.
If that is not the case, then please give some details of your machine specs and Operating System
I give up, Thanks your answer.
'Wire Bounding Box' 'Solid Bounding Box' 'Wireframe' 'hidden line' they don't show anything.
But the 'Lit Wireframe' can use,I will use it.
My graphic card drivers is the newest,I had try the older drivers,32bit 64bit daz studio (my system is Win7 64bit)
They just works fine in virtual machine.
Thanks again.
