Pesky animation timeline thing
Sometime in the past, between "then" and "now" the timeline bar trundled from its nice safe "0" position to the nasty "3.xseconds" position. I don't know exactly when, because I never have the sequencer panel open.
So my question is, how do I get the timeline back to zero, without losing several days worth of changes and edits? Can I just drag all the little triangles along to the left? What about the triangles that are already there?
Thanks. :)
(there really should be a lock on that thing - it's a menace!)
  • DUDUDUDU Posts: 1,945
    Just drag the left limiter (a cursor up on the timeline) until your prefered position and this position become your zero image...
    If the animated object is not rigged, you can delete the frame 0 keyframes and drag the keyframes generated further down the timeline back to frame 0. If you do this with a rigged figure it can blow up in all sorts of weird ways.
    Thanke Dudu and EP. At this stage, nothing's rigged (it's just vertex models), so I'll give that a try tonight, after the relatives have gone.
