Where is the dragoneggsbase?
Hello,
I downloaded the dragonessbase (https://www.daz3d.com/the-dragoneggsbase) and I am sure it was installed by the Instal Manager, but I don't find it on the Daz Studio app. Do you know in which section it is? I tried to use the search feature, but it didn't find this dragoneggsbase...
Thank you in advance for your help!
  • scorpioscorpio Posts: 8,533
    It will be in the Poser runtime.
  • yuyu.atemyuyu.atem Posts: 497
    Thank you very much! Does it work only for Poser? I thought it works also for DazStudio?
  • It will appear, at least, in the Content Library under Poser Formats then the content directory tou isntall to and then the library path within that.
  • Llola LaneLlola Lane Posts: 9,647
    Yes it works with Daz.. it's just in the Poser runtime.  :)
  • JOdelJOdel Posts: 6,322
    Quite a lot of the RDNA products were originally for Poser. The Geometry works fine in Studio. The mrphs usually work fine in studio. Sometimes you need to tweak the materials in the surfaces tab. They were not created for Iray.
