What makes posing movement faster, better GPU or CPU?
JamesJames Posts: 1,191
edited August 2023 in Daz Studio Discussion
When there are too many objects in the room, or high value of collision itteration, posing movement becomes laggy.
What could make it faster, better GPU or CPU?
Post edited by James on
  • Both.
    Somethings, such as Smoothing modifiers, are CPU, while other things, such as Mesh Resolution, are GPU.
    If you're having issues with posing, i'd suggest turning off smoothing modifiers until you're ready to render, as well as reducing the amount of, visible, items in your scene.
    You can also turn your Viewport setting(Edit>Preferences>Interface(tab)) down to improve performance(GPU).
  • crosswindcrosswind Posts: 10,356
    edited August 2023
    If there're lots of high definition wearables (clothing, accessories, some 3rd-party anatomical elements or geo-grafts, etc) on the figure, they'll all make posing laggy because of smoothing iterations, pJCM resolving, etc. In some cases, hiding them and deactivating smoothing even don't help much. I myself have a pretty robust rig, but laggy things happen from time to time...
    If you're facing very laggy situation, you may try to save all werables as a preset,  delete them all, then fast posing is back. When it's done, load back preset and tweak a bit.
    Post edited by crosswind on
