Shell settings Always Get turned On back after a character re-apppear
Sometimes accidetanly I deleted a character, if I undo, the shell that I've turned off, got turned on back. Is there a solution to this?
It's annoying.
  • crosswindcrosswind Posts: 10,357
    If you set Opacity slot of surface on the geoshell to 0, they won't appear after undo. But if you use toggles of Visibility, nope, there's no workaround...
  • Be aware that visibility actually hides the mesh, so it doesn't get sent to the render engine, while opacity just makes it see-through, so it is sent to and evaluated by the render engine.
