Flashy Hair for Genesis 3 Female(s) - Questions
cosmo71cosmo71 Posts: 3,609
edited October 2015 in The Commons
Well, I have bought Flashy Hair for Genesis 3 Female(s) and I do really like that hair but I have a question, why does this hair do not follow the head moves correctly? If I just move the head via twist from left to right the strands and also the sides of the neck of the hair do not have the same distance or position to the head, the distance change also the distance from the sideburns to the ears changes, means if you move the head via twist to the right side the distance between the left sideburn and the left ears gets larger while the distance between the right sideburn to the right ears gets smaller, equal the neck sides and the strands to the head. And this is just the head twist, if you know have other movements (head/lower and upper neck) also it is getting much worse. With the smoothing modifier and the collision you can fix some things but not everything (like sideburndistance to ears).
Is there a way to fix this? I mean, if I just move the lower and upper neck it is okay (twist) but not if I move the head. If I bend the lower and upper neck I got problems with the backneck of the hair and have to fix this via the adjustment morphs or I raise the value for the collision iiteration to 10-20 what causes bad results if you have the hands up to the head. sad
Don`t get me wrong, I really like the hair and use it and it works for a lot of poses but not for some I use for my images so some things could have been a bit better.
What most disturbs is the thing with the distance to the ears (sideburns and neck) and that cannot be fixed. there is no adjustment for this and the collision has no influence on that, so this is a bit grrrrrrrrr.
1553 x 761 - 230K
Post edited by cosmo71 on
