Is there a map that controlling a cloth area to body morph?
JamesJames Posts: 1,189
edited August 2023 in Daz Studio Discussion
Is there a map that influencing area of a cloth to body morph?
Like for example if breasts get bigger, I want wider area of the cloth get affected. How to do that?
Post edited by James on
  • felisfelis Posts: 6,503
    No. Morphs generate a projected morph on the clothing, and you cannot control how that behaves (other than creating a dedicated morph in the clothing) (unfortunately).
  • crosswindcrosswind Posts: 10,249
    A morph does not have a 'weight'... More likely you wanna fix a PBM on the garment.
    For instance, if a morph Breasts Size is dialed on the figure, there'll be an auto-follow PBM triggered on the garment. You may directly fix this PBM (to make it larger / wider) or create MCMs as sub-components of this PBM. In the way of the latter, you may use ERC KEYS to make various subtle changes on those MCMs...
  • A Rigidity Map can modulate morph projection, but it is one-size-fits-all.
