GoM's Dwarf for Genesis - Can't Find the Morphs
I went to use GoM's Dwarf for Genesis tonight and there don't appear to be any morphs (the set is supposed to come with both head and body morphs). There are textures but nothing else. I uninstalled it and reinstalled it and nothing changed. I downloaded the zip file and I don't see any morphs in there either. I have his goblin and orc sets and they both have folders for morphs. Is this a known issue? Am I spacing out and missing something? Any info would be appreciated.
    The presets in the Content Library are only for the materials, the morphs are in the Parameters pane under "Actor > Male > Fantasy SciFi" and "Actor > Head > Male > Fantasy SciFi"
  • maraichmaraich Posts: 495
    Thank you. I kept looking under "shaping" and nothing was working there. My dwarf is coming along nicely now. )
    Note that what appear to be morphs in the Content Library tab are all-or-nothing settings — they must be completely off or full on. When you use the actual morphs in the Parameters tab, you can set them to a value between off and on. This can be important when you mix morphs, some morphs at full on do not mix well, you might have to turn them down a bit.
  • Glad you got it figured out. Hope you like the set.
