How to change a G9 figure shape to default G9 shape ?
Hi, so I'm trying to apply some shape preset to Julia 9 but it just turns out ugly. I figured it might be cause of the shape which comes pre-baked with the figure and unfortunately there's no "Remove Body" or "Remove Head" option. What should i do in this case ?
  • Load the default figure in the first place. Then one can mix 'n match the various morphs in the gene pool. When a suitable combination is discovered, select the figure and save out a Shape Preset. When the option dialogue presents, first uncheck the root figure. Then right-click and select the option to select all that were changed. You might want to double-check what has been selected, adding or deleting a few before accepting.
  • crosswindcrosswind Posts: 10,249
    edited August 2023
    Go to Parameters pane, select Currently Used, filter "Julia" then tweak the vlaues of the morphs.
    Post edited by crosswind on
    Yup, it worked. Thanks a lot ❤️
