Alias Property Not Added to Node
I've noticed my load times for g8male figures has become a lot slower.  I looked at the log and there are about 300 entries that say this:
2023-08-12 15:06:27.688 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(9345): Alias property not added to node.
2023-08-12 15:06:27.688 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1744): Property alias not created!
2023-08-12 15:06:27.690 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1744): Property alias not created!
2023-08-12 15:06:27.690 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(9345): Alias property not added to node.
2023-08-12 15:06:27.691 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1744): Property alias not created!
2023-08-12 15:06:27.691 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(9345): Alias property not added to node.
2023-08-12 15:06:27.693 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1744): Property alias not created!
2023-08-12 15:06:27.693 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(9345): Alias property not added to node.
2023-08-12 15:06:27.695 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1744): Property alias not created!
2023-08-12 15:06:27.695 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(9345): Alias property not added to node.
2023-08-12 15:06:27.696 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1744): Property alias not created!
2023-08-12 15:06:27.696 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(9345): Alias property not added to node.
2023-08-12 15:06:27.698 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1744): Property alias not created!
2023-08-12 15:06:27.698 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(9345): Alias property not added to node.
2023-08-12 15:06:27.699 [WARNING] :: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1744): Property alias not created!
It's actually not about the load times as it is that my basic figure has a morph applied by default.  I've zeroed it out and saved it.  I deleted the genesis 8 male starter and reinstalled it.  I can't figure out what character did this.  I follow a guy on Patreon that creates characters as well as some Renderosity purchases.  Could that have made some changes to the base character?  None of my morphs (when I look at the sliders) is on.
Here are a couple of examples I found in the log file about morphs being automatically installed.
Here are what the character looks like by default and when I zero it out.
https://ibb.co/ZSxNZ8x
The other issue is that because the Basic Male loads with these defaults it screws up any morphs.
Here is an example of when I apply the "Ali" morph to both.
https://ibb.co/7RWyBrq
Any help would be greatly appreciated.
Sorry, I tried uploading the images directly but it stalled.
    1. Load the Dev Load version of the figure
    2. Edit>Figure>Zero>Zero Figure Shape
    3. Edit>Figure>Memorise>Memorise Figure Shape
    4. File>Save As>Support Assets>Save Modified Assets
    in the dilogue for the last step note what is listed - those should tell you which products were used, check for updates and if there aren't any report them (to Daz for items from the store, to the artist for freebeis and items from other stores).
  • BejaymacBejaymac Posts: 2,005
    The "alias" errors are from installing a Pose/Expressions product that has badly done Alias DSF files, either uninstall the product, or head into G8M's Morphs folder and find and delete the Alias files.
