• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Blender to daz.
sulivaracesulivarace Posts: 19
August 2023 in Blender Discussion
Good morning,
Do you know one can find information to cleanly export meshes from Blender to daz studio in anticipation of production creation.
I want to do mainly staticmesh, house, castle, environment etc...
I have some problem with the textures which does not apply in obj.
On youtube there are tons of tutorials for exporting daz to blender but for the reverse, not much, so if you have any links I'm interested, thank you.
  • Richard HaseltineRichard Haseltine Posts: 108,982
    August 2023
    If this is about OBJ settings, folow the tutorials to export anything (justa s pehere or cube will work) and in the options dialogue, after setting the values, use the Save button to create a new preset. You can then use that preset in the options dialogue when importing.
  • lilweeplilweep Posts: 2,775
    August 2023
    You will probably have to manually apply textures to your shaders in Daz Studio in the Surfaces tab after importing obj,
    As there's no bridge that I am aware of between Blender to Daz Studio, so will need to use obj or other standard.
    If there is a more efficient way, I would love to hear it as I have been importing using obj and then manually setting up the textures in Surfaces tab (which is tedious for big environment with many assets).
    Hopefully one day there will be Blender->Daz bridger or USD importer for Daz Studio.
  • benniewoodellbenniewoodell Posts: 2,000
    August 2023
    Once in awhile, and it's really a crap shoot, the textures will show up in Daz from Blender, but the OBJ file has to be in the same folder as the textures. So anytime I bring objects from Blender to Daz, I always put the OBJ in the folder where the textures are and I'd say one out of five times everything shows up in Daz. Don't know why or how, but occasionally I get lucky. Seems like it happens more if it's a smaller object without many material zones, Kitbash 3D kits never come in with textures as I think there's too many, it's usually objects that I create.
  • PadonePadone Posts: 4,055
    August 2023
    In general blender only exports textures from the principled shader. Other shaders may be too complex to export.
  • sulivaracesulivarace Posts: 19
    August 2023
    Thank you for your answer, after many tests I have come to the same conclusion as you, I would nevertheless like to react to the first message, what are the optimal export parameters in obj to daz?
    If you have good source youtube or other I am a taker.
    I watched a lot of the tutorial on this point but everyone has a different way of exporting.
    For the moment, the most qualitative result that I have found and the following one, as said above, the complex shader editor cannot be exported with exactness, for example if we resize the normal and any texture in the shader is not taken into account.
    I started with baking then I compared the result with "handmade" with photoshop by treating each of the textures.
    The result obtained with the second method which is much longer is much closer to the original model than baking, especially with the simple bake addon.
    August 2023
    you can load an .mtl file with you obj but an obj's .mtl file isnt going to be able to put the texture maps into the correct slots on daz studio shaders, bar some.
    August 2023
    i didnt 100% understand what you said, but yes if you bake out your Shader Editor in Blender to a set of PBR standard texture maps, i suspect you should be able to emulate the effect of your shader setup from Blender in Daz Studio.
    August 2023
    Yeah, I honestly don't know what the mtl file is, I just import the OBJ and sometimes I get lucky and everything shows up exactly how it's supposed to. Kind of keeps me on the edge of my seat with anticipation as I hit import lol.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
