Polygon Count List of Gen 4, G1, 2, 3
xyer0xyer0 Posts: 6,507
I have fruitlessly searched online for a polygon count of the base models (though V4 is listed on a wikipedia page). Does anyone know what they are or how I can find them out within DS?
  • AtiAti Posts: 9,208
    If you have the Decimator plugin, that will tell you, and also let you change it.
    If I did everything correctly, then these are the default counts:
    G1: 37552
    G2 male: 41266
    G2 female: 41066
    G3 female: 33872
    Window > Panes > Scene Info
    V4  66,830
    Genesis  18,872
    G2F  21,098
    G3F  17,000
    V4  66,830
    Genesis  18,872
    G2F  21,098
    G3F  17,000
    This is easier. :)
    Why does it show two numbers though? G3F shows "Total faces: 33872 / 17000"
  • xyer0xyer0 Posts: 6,507
    V4  66,830
    Genesis  18,872
    G2F  21,098
    G3F  17,000
    Thank you so much, Fixmypcmike. As always, you ROCK!
    G1: 37552
    G2 male: 41266
    G2 female: 41066
    G3 female: 33872
    Thanks Ati2. I have Decimator, but I have not yet used it. It looks like your totals are twice the totals tha Fixmypcmike posted.
    G1: 37552
    G2 male: 41266
    G2 female: 41066
    G3 female: 33872
    When you view the scene info, it shows both numbers for the total number of faces. Decimator shows and uses the higher number of the two.
  • prixatprixat Posts: 1,627
    The larger number sounds like a triangulated poly. count.
    (There are some tri-polys already in the mesh, that's why the numbers are not precisely double the value.)
  • I was wanting to compare Daz models with other commercially available models and this helps so much. Thank you!
