Need help restore
Hi all.
I have seem to messed up something in the "parameter - posing - shaping" menu in the lower right corner.
If I click on a part of a figure, for example the foot, I was before able to pose that part. But now I only select the hole figure if I press a part.
So if I click on the genesis 9 left foot I only select the Genesis 9 - not the foot.
Anyone?
BR// Daniel
  • felisfelis Posts: 6,630
    Assuming that you are using the Universal Tool to select, go to Tool Settings and set 'Node Selection Mode' to "Root Node First".
  • crosswindcrosswind Posts: 10,356
    Better switch to "Node" otherwise you have to click twice to select a single foot if no figure / joint is selected...
  • Thanks.
    That solved my problem.
    BR// Daniel
