Selecting clothing - question
cosmo71cosmo71 Posts: 3,609
edited October 2015 in The Commons
I have a clothing and selectable is "on" but I can`t select the item, anyone an idea?
Post edited by cosmo71 on
  • frank0314frank0314 Posts: 15,114
    Right click, select all I believe
    When you try to select are you getting the base figure the clothing is on instead of the clothing?
    If so, have you tried selecting the clothing item in the Scene tab?
    Right click instead of left click, and carefully read the "Select" options in the drop-down menu. There are separate options for selecting the figure, and for selecting the clothes. This will happen any time you have one object fitted to another, it isn't just a clothes thing.
  • cosmo71cosmo71 Posts: 3,609
    I know but that does not work for this clothe, I do not know why, selectable is checked "on" so it should work but it does not.
    I know how to select an item in a scene also if it is fit to another figure but it does not work for this clothe
    exactly and in the scene tab can select it but not directly in the scene with right click even selectable is checked "on"
    It is not that big problem but I would like to know why this is so.
