tokens issue - tokens cannot be unapplied once applied...also don't recognize freebies
jardinejardine Posts: 1,223
i like the tokens.  but we need to be able to remove the token discount from a cart once applied, just as we're able to remove a discount code.
points;
once tokens are applied to a cart, they're stuck there.  they will be applied to your next transaction, whether that transaction is actually a purchase or not.
once tokens are applied to a cart, even emptying the cart doesn't reset their status.
the token implementation doesn't recognize that a cart with nothing but a freebie or two in it does not need discounting.
i just lost a token that way.  happy it was only one.
be nice if daz could add an interface option to remove the token discount from a cart (or carts, really).
j
  • sazzyazzcasazzyazzca Posts: 495
    Right beside the number of tokens there should be plus and minus signs. I use those to remove the tokens one by one.
  • Charlie JudgeCharlie Judge Posts: 13,641
    Use the - sign to run the tokens down to zero and IMPORTANT: then be sure to use the "Apply" button to actually apply zero tokens.
    YES! That part is very important and I neglected to mention it. Thank you!
  • GoggerGogger Posts: 2,535
    Thanks everyone - I learnt somethin' useful. (Seriously!)
