Display dark
I must have inadvertently clicked some button in Viewport area, and now everything is dark.   How do I set the default so area appears lit?
    edited October 2015
    If you mean just the Viewport contents:  CTRL-L
    Post edited by fastbike1 on
  • Yes, just talking about the viewpoirt, where the background is black and the grid is white lines on black for the floor plane.  Tried CTRL L and not changing anything (nor does it change if I toggle that preveiew lighting from menu dropdown).  Nor does restarting the program.  Any other suggestions?  Thanks.
    If you are using a Camera, you may have turned of the 'Headlamp'   Go to the Patameters pane with the Camera selected, and switch the headlamp back on.
