About light in closed room
Hey everyone what's up :)
I wanted to ask I bought this : High School Toilet | Daz 3D
I really like how it looks and I must say this room is really Havey Render and he have "yellow light"
My question is can I change the light to white? or its on the walls and nothing be change?
+ Can I make it somehow more "soft" to render?
Thanks! Hope I make my self clear and if not let me know I will try to write the problem again haha ^^
  • felisfelis Posts: 6,643
    I don't have the set.
    You need to find out if the light source are emissive surfaces or lights.
    For both you can change the temperature, as it is the temperature that gives the color. Low values (<3000 K) towards red and higher towards blue. Daylight is around 6500 K.
    But be aware of, if the walls are yellow they might reflect yellow light, so if, you might consider changing their toning too.
  • prixatprixat Posts: 1,630
    If it's an overall colour cast, then the easiest way would be in Tonemapping.
    You can change the 'White Point' to the same 'very pale yellow' you're seeing, that should get rid of it!
    @prixat @felis thanks to both of you I will try it out!!! :)
