Hair problems - Bad Hair Day
HorusRaHorusRa Posts: 1,665
Why is it sometimes hair on a character can appear really super thin once rendered? Looks like the hair was thinned way too much and you can see individual strands with large gaps between each other.
  • kaotkblisskaotkbliss Posts: 2,918
    It could be the way the render engine is interpreting the opacity map. You could try turning the opacity down a bit (increase the number, 100% is no opacity)
    This should make the hair appear thicker.
  • HorusRaHorusRa Posts: 1,665
    edited August 2017
    Post edited by HorusRa on
    What hair exactly, and what figure is it fitted to.   Can you also please post an image of what you are seeing?
    Then the map is not being correctly 'corrected'.  Gamma should be 1.0 for all control maps...you can check this by clicking on the image in the Cutout Opacity slot in the Surfaces tab and clicking on Image Editor.  With gamma set at 0, Studio will guess as to what it should be...and for control maps, it should not be 'corrected' (that's what the 1.0 means, in this case)l.  But it will guess based on the location AND the header info in the file.  If that info says the image is an RGB image (color) instead of greyscale, it will most likely guess wrong.
    edited August 2017
  • ToborTobor Posts: 2,300
    Common problem for Iray. There are a couple of third-party add-in products that replace the textures and transparency maps and make them more Iray-friendly. My goto for this is the UHT hair add-in by Slosh, available here.
    You could also manually "thicken" the hair by creating and/or repainting any texture and trans maps. The add-in products don't do anything you can't do yourself, but they make it simpler -- basically click-and-render.
  • VhardamisVhardamis Posts: 576
    Out of Touch has an iray hair shader set to that i love over in his rendo store:
    OOT IrayPair Hair Shaders for DAZ Studio & OOT IrayPair Hair Shaders for DAZ Studio expansion
    I get some really decent renders on even old gen 4 hairs with it.
