Render looks grainy and pixelated.
Hello, friends. As you can see, this render isn't exactly meeting standards. Now, you are probably thinking : "Damn, those grains and pixels are ugly, he needs to add more samples."
Problem is, I have set the samples to 15,000.
Here are the settings I'm using :
Anyone know why I am getting this grainy mess?
    No images are attached - just a list of the same filename over and over.
    Normally when the render is too grainy is because it has not rendered for long enough and/or there is insufficient light. Max samples is only 1/3 ways the render will auto-finish. If when the render is stopped it does not look good enough you can pop-out the side panel to the left using the teeny-tiny handle, increase the settings and continue the render.
