while zooming into a scene light gets darker
When I zoom in a scene, the environment is getting darker. In this scene I'm using no light (except some light emitter) and "preview lights" is also off.
what am I doing wrong?
1167 x 1041 - 517K
1164 x 1070 - 1M
  • frank0314frank0314 Posts: 15,102
    edited October 2015
    NM I didn't read correctly.
    Post edited by frank0314 on
  • If Preview lights is off then you are using the headlamp on the camera in preview, and if you have only emiittersyou are using it in renders unless you have switched it off. Since the headlamp is offset from the camera zooming close will reduce the light on the areas you are viewing.
  • PixelboyPixelboy Posts: 32
    edited October 2015
    Headlamps are off. I put three spotlights into the scene; same result.
    In this modes a have the problem:
    Wired Shaded, Smooth Shaded, Wire Texture Shaded, Texture Shaded, Cartoon Shaded and Solid Bounding Box
    1000 x 541 - 414K
    886 x 637 - 147K
    Post edited by Pixelboy on
  • But as I said, if Preview Lights is off then you are using the headlamp anyway.
  • Now I've got it smiley
    Thank you!!
