Is it possible to make the object inside the figure not move?
Good day!
Let's say there is a figure that has a movement animation. If you drag an object into it, it will follow it. Is it possible to make this object stay inside the figure but not move?
  • felisfelis Posts: 6,502
    If the object isn't parented to the figure, it will move independently.
  • frank0314frank0314 Posts: 15,100
    edited July 2023
    Do you have an example? Depending on what it is I would think if you move it to where you want it and parent it, it should work fine
    Post edited by frank0314 on
