Trackball Tool?
DekeDeke Posts: 1,636
edited July 2023 in New Users
How do I make the Trackball took appear in the upper left corner of the main window?
Update: It suddenlty appeared. Maybe it depends on what is highlighted.
Another question, why do some characters separate bend and twist controls? Really frustrating having them separate.
Post edited by Deke on
  • Richard HaseltineRichard Haseltine Posts: 111,958
    Yes, the pose control does depend on selection.
    As for Bend/Twist - do you mean bones, rather than controls? That is because with general weight mapping (Genesis 3+) theer is only one map for each bone, but generally bending is confined to the hinge area (it's the pivoting of a bone around its end) while twisting is usually spread along the limb (it's two bones moving relative to each other) so two joints are needed. However, Daz Studio suports having clones of properties and that is used in the Genesis 3+ figures so that you can twist the twist bone using the (visible) control on the bend bone and vice versa.
