Custom Layout and Favourites?
What is the exact method of customising the layout, by that I mean saving it with pose shortcuts etc. in the favourites.
Is just saving the layout sufficient?
Do I need to export each element (Toolbar, Menu and Actions) first, and then select them, when saving the layout?
I ask because I've had varied results when trying each and every way, sometimes a favourites shortcut appears to be saved, and other times not, despite having repeated the save method.
I would just like to know the correct intended method for saving a custom layout.
  • Richard HaseltineRichard Haseltine Posts: 111,996
    A layout certainly should include all of the sub-parts. Check that the files are not in the wrong place if they seem to disappear.
