refraction values for massive glas object?
cosmo71cosmo71 Posts: 3,609
edited October 2015 in The Commons
has someone an idea how the refraction values for a massive glass object can be? I use 3Delight
Post edited by cosmo71 on
  • FishtalesFishtales Posts: 6,218
    edited October 2015
    It depends on the glass. Refractive Index can range from 1.45 to 1.9.
    Post edited by Fishtales on
  • cosmo71cosmo71 Posts: 3,609
    ah okay, that helps and what is the color for?
    What colour?
  • Refraction is a surface property, the size of the object does not matter (unless there are lots of bubbles inside it, each with their own surface contribution). If your glass looks unrealistic it may be a lack of absorbption - glass is not fully transparent, the amount of light transmitted should decline as the size increases.
  • KhoryKhory Posts: 3,854
    3dl or Iray? 3dl you need to include a full 360 degree environment or you get odd behavior when you try and render glass.
  • KeryaKerya Posts: 10,943
    First message says 3delight ...
    That said - glass and liquids need a "skydome" 360° environment to render fine - which is why Fisty included one in her free Liquids set: http://www.sharecg.com/v/82337/
    Fishtales said:
    What colour?
    refrection color
    you got refraction color, refrection strength and index of refrection
    Refraction colour is the colour you want refracted through the substance, normally set to white. For a prism all colours would be refracted and a rainbow would be seen as the transmitted colour. For water you might want blue to make the sea tropical :)
    ah okay, thank you smiley
    3Delight, my machine would puck if I do Iray sad
