can't find GenX transferred into Genesis canine teeth
3DthiSS3DthiSS Posts: 146
edited October 2015 in Daz Studio Discussion
hi all
need some fangs to finish a vampire scene ....was using a fang morph I found on cgshare but it stopped working after I closed the scene...have deleted it .
I've transferred all of my V4 morphs into Genesis however I can't locate a controller for the canine teeth in the Shaping tab .
any ideas would be appreciated...been trying to sort this out for hours...groan lol
thanks
Post edited by 3DthiSS on
  • LindseyLindsey Posts: 2,017
    Not all morphs display on the Shaping tab.  You'll probably will find it on the Parameters Tab.  With Genesis selected, go to the Parameters Tab, select the All group and type in canine in the Search box and see if it shows up.
  • 3DthiSS3DthiSS Posts: 146
    hi Lindsey
    yes that did the trick!..well sort of .
    I've got the canine bottom appearing but no canine top will appear even though there's a controller showing for it....have checked the GenX folder and there is a .dsf file for that morph.
    hey my bad.
    the top are appearing...I didn't realize that the top canines are spaced farther apart than the fang morph I was using...just had to open the mouth and lips  a bit wider.
    actually prefer that fang morph but others have reported back with similar cases of it suddenly not working.....wonder what could cuase something like that.?
