Installation Issue on mac os
- Install Manager cannot find a required path. The package for "Photoshop 3D Bridge for DAZ Studio 4.8+ (Mac 64-bit)" requires that the installed path for "Photoshop CC, CS6, CS5, CS4 (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
- Install Manager cannot find a required path. The package for "Photoshop 3D Bridge for DAZ Studio 4.8+ (Mac 32-bit)" requires that the installed path for "Photoshop CC, CS6, CS5, CS4 (32-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
The error messages are telling you that you need to go to the Applications tab in Settings pane inside DIM (gear icon at the top right) of the UI) Enter the path to your copy of Photoshop, which must be CS5 or higher.
If you do not own Photoshop, then the plugin is of no use to you, so don;t install it.
You do have Photoshop?
Do you have Photoshop? If so you need tot ell the Install Manager - click the gear icon at top-right to open preferences, go to the Applications tab and click the + button; in the dialogue set the application name and version, then click the ... button to set the path to the application itself. Once you have done that you should be able to isntall the bridge.
