Daz Studio Path Space
ibr_remote aka infinity10
Where may I find information or documentation on the Daz Studio Path Space items in the Render options, please ? I will use them if I understand what they are for.
Where are you looking? The only settings I see with Path in the name are the path for the image (not sure why that is showing when it is set to go to a new window) and the max path length (which cotrnols how many times a light path can bounce before returning a final colour value, a means to speed renders in complex scenes at the expense of accuracy)
I also wondered... what is Path Space ?
If one looks under "Filltering" (show hidden)there is an option called "Path Space Filtering".
I can't figure it out either.
edit: it can enabled(un-hidden) by setting the Render mode to Interactive.
Well, these at least give soem idea of what it is in general terms:
https://research.nvidia.com/publication/2019-02_massively-parallel-path-space-filtering
https://research.nvidia.com/publication/2014-10_path-space-filtering
