can regency dining bundle be used in daz?
VicSVicS Posts: 1,273
edited July 2023 in Daz Studio Discussion
it says for poser but poser things usually open in daz, at least the ones i got from rendorosity
I cant find it antwhere in the content library
https://www.daz3d.com/downloader/customer/files#prod_8404/
Post edited by VicS on
    Hi Vic,
    I don't have that product but I would have thought so. However, the bundle probably won't show up as that is just an "umbrella product" that contains the three other products.
    If you have installed it then it should show up somewhere under Content Library -> Poser Formats -> Library -> *
    I don't have a lot of Poser stuff so would not want to guess at the sub-catageories under the Library but hopefully it should be reasonably easy to guess.
    I don't think it will have Smart Content so you'll have to look for it that way.
  • VicSVicS Posts: 1,273
    I did check here
  • felisfelis Posts: 6,643
    If I have trouble finding a product I go to Content Library > Products > 'product name'
    I only have one of the products in the bundle, but it works fine.
    I assume you have the library where you have installed it added under Poser formats in addition to Daz formats - if you are installing via DIM/Central to the initial base library then I think this should already be the case but just wanted to check.
  • Richard HaseltineRichard Haseltine Posts: 112,021
    edited July 2023
    Please use the product page link, https://www.daz3d.com/regency-dining-bundle , rather than the product library page - that is available only to those who have purchased the set.
    I've certainly used the items in Ds in the past, though note that they have 3Delight materials rather than Iray. Make sure you are isntalling the base product and the StudioCF (companion files) for each as the latter is only material settings.
    iinstalled through central-
    ok ill uninstall and reinstall like you said
    is uninstalling needed before reinstalling?
    edited July 2023
    i reisntalled through IM-it still hasnt showed up anywhere do I eed to download it from the product page instead?
    where did you find your regency set in the content library if you remember?
    thanks
    The only reason to uninstall before re-installing would be if there had been an update in the time between where filenames may have changed.
    I have now opened my Daz and it seems I do have a different product by that vendor, so I can now be a bit more confident in saying that you should be able to see those products under both:
    1. Content Library -> Poser Formats -> Library -> Figures -> Ness Period Reproductions
    2. Content Library -> Poser Formats -> Library -> Props -> Ness Period Reproductions
    In my case the "Figure" was a train carriage and was stored in that first location because it has bones (moving parts).
    i did do it thorugh the zip files too
    i already had the tableware set which is under R under products but the other two sets still not there, i did restart daz
    Is Install Manager set to show Poser files - Download Filters button on the ready to Download tab.
    edited July 2023
    ok found them all finally-thank you everyone
