How do I get better render times?
I started with an EVGA GTX 750Ti (2gb of RAM) video card and though that is a decent card it was slow when it came to rendering the iray stuff. Now I have an EVGA GTX 980 (4gb of RAM) and I don't really notice a difference in rendering speeds.
What else can I do to improve rendering times?
My system as is:
CPU: 4930k overclocked to 4.3 ghz
RAM: 32gb of G.Skill Trident X 2133mhz (4 x 8gb)
MB: Asus Rampage IV Black Ed
Graphics: EVGA GTX 980 4gb SC ACX 2.0
  • Oso3DOso3D Posts: 15,131
    Are you sure you've selected GPU rendering?
    Because those two should be hugely different.
    Without seeing a scene, lighting in it and what the render times are, 'slow' is meaningless...
  • Are you sure you've selected GPU rendering?
    I did not know about this option. I take it this is an option in the program.... I'll look and see if I can find it. Thanks!
    edited October 2015
    Download SickleYield's test scene from this thread and run it...post your render times.
    http://www.daz3d.com/forums/discussion/53771/iray-starter-scene-post-your-benchmarks
    Post edited by mjc1016 on
    GPU rendering:
    On the lower right (probably) are a series of tabs. Surfaces, shaping, etc.
    Click on Render Settings, then Advanced tab in the panel that comes up. There will be a check box for CPU and GPU rendering -- you want to at least attempt GPU-only, so uncheck the CPU and make sure GPU is checked.
    If this wasn't set up that way before, it should make a huge difference unless you have an absurdly huge scene that won't fit in GPU. (But I have a 970 and have seen huge jumps from a 750 or similar, I forget exactly which I had before)
  • nicsttnicstt Posts: 11,715
    Use them both; should be an increase there.
    Reduce the resolution, it will render faster.
  • GPU rendering:
    I found it. Those settings did not seem to make a difference. The scene I am trying to render is a Harem scene (looking for a fantasy pool scene like you may have seen in Roman times) with three bodies in it so far. I believe two of the bodies are in Iray.
