G8 teeth no longer fit on my custom G8
Hello creatives,
I am using G8 and I have customized it in daz and then I did other tweaks in Zbrush (never touch the teeth) and when I return G8 to Daz the teeth no longer fit well, they look smaller and separated from each other, I bought a jaw to modify from there, but does not make changes to the teeth. Could someone please help me solve it and have normal teeth.
Thanks community
  • Richard HaseltineRichard Haseltine Posts: 111,371
    There are default morphs aplied to the teeth, though their effect should be reversed out if you are using GoZ to send the mesh to ZBrush and to bring the morph back.
    Did you divide the mesh in ZBrush? That can cause issues as restoring to the zero division level leaves some smoothing in place.
