• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Cinema 4D Discussion
C4D Bridge: Shader creation even worse than before
XanathonXanathon Posts: 88
July 2023 in Cinema 4D Discussion
I have no idea where I can leave feedback for the C4D bridge so someone from the devs sees it, so I do it here.
With the latest version the prop and figure material import are even worse than before, textures are mapped into the wrong channels, there are diffuse/reflection imports mixed up. Also bump and normal settings are completely wrong. I cannot understand how this can be rolled out as a working bridge, did no dev actually test if this works? Redshift conversion does not work at all, only one material is converted and here the textures are plugged into the wrong ports and/or have wrong settings.
Maybe the devs should ask someone with some knowledge about C4D, Redshift and Octane instead of tinkering themselves?
The free bridge is advertised to sell more assets to use them with C4D. Practically this only works VERY bad if ever.
  • peterpeterpeterpeter Posts: 34
    July 2023
    I don't think the devs read this forum anymore, but they are present on the Github page and they read reports there. You can submit your issues here:
    https://github.com/daz3d/DazToC4D/issues
  • GordigGordig Posts: 10,799
    July 2023
    I use the bridge knowing that I'll need to set the shaders up myself (I use Arnold, which isn't supported by the bridge), and it works great for my purposes.
  • Willy2Willy2 Posts: 189
    November 2023
    Shaders are specific to each render engine. Don't wait for a shader converter between two different renderers, because that's impossible to do correctly.
    On the other hand, between Daz Studio and Cinema 4D, you should be able to recover the texture, alpha, bump, transparency.
    Some rendering engines offer shader converters with the shaders of the software on which they are installed, but this conversion is only approximate and will never satisfy a professional.
    November 2023
    I would also add that in renderers, channels are never organized the same way.
    In addition, between two different versions of 3D software, there may be a reorganization of the channels for the same rendering engine.
    Wanting to do a shader conversion doesn't make much sense (it's a beginner's wish)
    In fact, we create some of the shaders based on the light sources.
    I therefore advise you to initially make a good adjustment of textures, alphas, bumps and transparency.
    Next, you will create the lights coming from the renderer (and not the lights coming from Daz 3D)
    When the lights are well placed and lighting the scene as you wish, you can move on to the final step, finalizing the shaders.
    For adjusting shaders you can start with specularity which is a fairly easy concept to understand.
    Then, you can adjust the opacity which is important for the skin (there are lots of tutorials on the internet)
    There are other shaders but if you have reached this stage, your work will already give you satisfaction.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
