dForce Spandex Vinyl Rainwear Outfit - Missing Textures for G8
Depa3DDepa3D Posts: 34
Whenever I load [dForce Spandex Vinyl Rainwear Outfit] this product on a G8 and try to apply the full body shell, or textures to it, the body appears to be missing the setting information.
It looks like it's setup for Uber on the body texture node. I tried loading/applying the base Iray shader to it then one of the materials and it still didn't work.
Any advice, or others having the same issue?
And, apparently I can't upload any images. I try attach a file on here and it just stalls out.
  • felisfelis Posts: 6,504
    If you look in the log (Help > Troubleshooting > View log file), what does it say when you try to apply a texture?
  • Depa3DDepa3D Posts: 34
    2023-07-09 18:27:37.131 [INFO] :: Prepare asset load (merge): /People/Genesis 8 Female/Clothing/PAMAWO/dForce Spandex Vinyl Rainwear/SR Tight Leotard Shell Genesis 8 Female.duf
    2023-07-09 18:27:37.131 [INFO] :: Locking viewport redraw...
    2023-07-09 18:27:37.131 [INFO] :: Viewport redraw locked.
    2023-07-09 18:27:37.300 [INFO] :: Native format content directories: 5
    2023-07-09 18:27:37.300 [INFO] :: Poser format content directories: 4
    2023-07-09 18:27:37.300 [INFO] :: Other import format content directories: 0
    2023-07-09 18:27:37.300 [INFO] :: Begin asset load (merge): /People/Genesis 8 Female/Clothing/PAMAWO/dForce Spandex Vinyl Rainwear/SR Tight Leotard Shell Genesis 8 Female.duf
    2023-07-09 18:27:37.326 [INFO] :: Determining missing assets...
    2023-07-09 18:27:37.346 [INFO] :: Setting textures...
    2023-07-09 18:27:37.349 [INFO] :: Scanning for addons...
    2023-07-09 18:27:37.351 [INFO] :: Creating node geometry...
    2023-07-09 18:27:37.355 [INFO] :: Creating materials...
    2023-07-09 18:27:37.431 [INFO] :: Resolving legacy figures...
    2023-07-09 18:27:37.431 [INFO] :: Preparing modifiers...
    2023-07-09 18:27:37.431 [INFO] :: Creating modifiers...
    2023-07-09 18:27:37.431 [INFO] :: Finalizing modifiers...
    2023-07-09 18:27:37.431 [INFO] :: Sorting property groups...
    2023-07-09 18:27:37.432 [INFO] :: Setting up follow targets...
    2023-07-09 18:27:37.451 [INFO] :: Finished asset load (merge): 0m 0.150s - /People/Genesis 8 Female/Clothing/PAMAWO/dForce Spandex Vinyl Rainwear/SR Tight Leotard Shell Genesis 8 Female.duf
    2023-07-09 18:27:37.774 [INFO] :: Unlocking viewport redraw...
    2023-07-09 18:27:37.774 [INFO] :: Viewport redraw unlocked.
    2023-07-09 18:27:38.509 [INFO] :: Loaded image: SR_FaceBody_Base_color.png
    2023-07-09 18:27:38.579 [INFO] :: Loaded image: SR_FaceBody_Opacity.png
    2023-07-09 18:27:38.708 [INFO] :: Loaded image: SR_FaceBody_Roughness.png
    2023-07-09 18:28:09.951 [INFO] :: Prepare asset load (merge): /People/Genesis 8 Female/Clothing/PAMAWO/dForce Spandex Vinyl Rainwear/Material Iray/SR Tight Leotard Shell 05 G8.duf
    2023-07-09 18:28:09.951 [INFO] :: Locking viewport redraw...
    2023-07-09 18:28:09.951 [INFO] :: Viewport redraw locked.
    2023-07-09 18:28:10.145 [INFO] :: Native format content directories: 5
    2023-07-09 18:28:10.145 [INFO] :: Poser format content directories: 4
    2023-07-09 18:28:10.145 [INFO] :: Other import format content directories: 0
    2023-07-09 18:28:10.145 [INFO] :: Begin asset load (merge): /People/Genesis 8 Female/Clothing/PAMAWO/dForce Spandex Vinyl Rainwear/Material Iray/SR Tight Leotard Shell 05 G8.duf
    2023-07-09 18:28:10.226 [INFO] :: Determining missing assets...
    2023-07-09 18:28:10.414 [INFO] :: Setting textures...
    2023-07-09 18:28:10.414 [INFO] :: Creating materials...
    2023-07-09 18:28:10.445 [INFO] :: Applying animations...
    2023-07-09 18:28:10.603 [INFO] :: Finished asset load (merge): 0m 0.458s - /People/Genesis 8 Female/Clothing/PAMAWO/dForce Spandex Vinyl Rainwear/Material Iray/SR Tight Leotard Shell 05 G8.duf
    2023-07-09 18:28:10.947 [INFO] :: Unlocking viewport redraw...
    2023-07-09 18:28:10.947 [INFO] :: Viewport redraw unlocked.
    No logged issues.
    I don't have it so I can't test.
    Does it work as expected for G9?
    Yeah, that's the odd thing. It works fine for G9. I'm wondering if the actual material DUF file is somehow corrupted or not calling for textures.
    I wouldn't know how to check that though.
    Tom
  • crosswindcrosswind Posts: 10,253
    Haven't found any problem as per what you mentioned... better post a Ss...
