Easier way to locking camera?
I know this is a very picky and lazy thing to ask but:
I know I can lock the position and rotation of a camera by going into parameters and locking all its sliders. But thats like 6 clicks to lock and 6 clicks to unlock.
Is there a faster way to clock everything with one click?
This is mostly for composite renders where I dont want the camera to move accidentally between renders.
Pls check this script from PA - MikeD : http://www.mikededes.com/daz-studio-lock-camera-script/
One-click to toggle camera lock/unlock, pretty convenient.
If you select the Camera and under the top-right corner menu drop down in the Parameters pane there is Lock->Lock Selected Item. That should do what you want I think. You can most likely asign a keyboard shortcut to it if you are going to use that often.
Thanks! That is much faster.
MikeD!!!
