How to Move a figure with LAMH fur?
Sorry, I can't seem to find how to translate x, y, z a figure with Look At My Hair. I didn't generate the hair, it came with the model. After I posed the figure, I saw it was blocking another object, and was hovering above the 'ground'.  I tried to move it. It was a cat figure by a chair leg. I can y translate the cat, but not the fur. I made a new group of the cat figure and the fur, but it won't move at all. I tried the utility 'move to floor'. Won't budge. Searching in forums, searching with on line search engines only seem to show stuff for sale, or some other problems. I tried LAMH and Look At My Hair. I need to know how to move a posed figure with the fur properly following. It poses with the fur ok, just can't move it.
  • crosswindcrosswind Posts: 10,276
    edited July 2023
    Normally, LAMH is generated on surfaces of the figure, its icon is just like a prop or sth., parent it to the figure before moving... Dose it work?
    Post edited by crosswind on
  • IceScribeIceScribe Posts: 694
    Having tested with another furry chihuahua, Zorro, it appears that it translates and does move to floor. So i went back to the other furry one, Brutus, and this model will now translate and move to the floor. Maybe I ran out of RAM while using a scene. By themselves, the models move as expected, after posing. Thank you for giving me that tip, because it was a simple way to check.
    Great! You're welcome blush
