DT Grace for Genesis 8 Female by Digital Touch - Limbs(legs) missing bump map
Hello.
I'm not sure if this is the right sub-section of the forum to request help/support for a purchased product.
Recently I bought DT Grace for Genesis 8 Female by Digital Touch and while everything works as it should, I did notice that the bump map for the legs, namely Legs BUMP.jpg, is just another copy of Torso BUMP.jpg
I would like for the author to fix the issue and replacing the duped texture with the proper one ... otherwise it would be a problem to use the whole skin texture as it is.
Thanks in advance!
  • LeanaLeana Posts: 13,499
    You should open a support ticket via Daz help center, Daz handles support for vendors and a lot of them don't use the forums.
  • Alien AlloyAlien Alloy Posts: 190
    Oh thank you.
    Do you know which section would include my issue?
    In the top-right corner of help center there should be a menu or a set of buttons. First sign in, then use "submit a request".
    Set the request type as "Technical support question", contact department as "Technical department" and Tech Ticket Tracker as "product issue"
    Once again, thank you very much
