Copy G8.1F surfaces and paste to the prop version the same figure is not working!
I exported the G8.1F figure as Obj then imported it back. I copied surfaces and pasted to the prop version the figure but the surfaces are clearly incorrect. This method works perfectly fine for G8F. Why does it not work for G8.1F or am I missing something?
  • Richard HaseltineRichard Haseltine Posts: 111,371
    If you want to turn a figure into a prop you can use Edit>Figure>Rigging>Convert Figure to Prop
    Copy/paste transfers settings, with a Genesis 8.1 character you would probably need to apply the PBRSkin shader to the surfaces first.
  • GabaGaba Posts: 1
    Thank you, Richard Haseltine. It works! I just need to apply PBRSkin Shader accordding to the original figure surfaces.
