Help About the Halloween Forest environments (have picture)
Hey! :)
I bought this environment for DAZ3D : Halloween Forest | Daz 3D
It works well but for some reason it makes some stripe different light up the rendering as you see.
Any one know maybe how can I fix this? thanks! :)
For some reason I cant upload the images in the file but here some link :
https://ibb.co/HVHbf5F
https://ibb.co/2PkD50Y
Thanks!
  • crosswindcrosswind Posts: 10,249
    edited June 2023
    Because Matte Fog / Ground Fog are turned on in Render Settings and with a small value of Matte Fog Visibility (m) - 800... you may reset the value of Matte Fog Visibility (m) to default (10000) or give it >5000, or even turn off Matte Fog or Ground Fog but use other Fog products instead, as you wish...
    Just tweak the Fog related settings to see the change, then make a decision...devil
    Post edited by crosswind on
    Thank you very much!!! I change it to 10.000 defult and it works well! THANKS! :D
    Great ! You're welcome. :D
    Oh by the way I love to render on 4k I know its up the time a lot and this Halloween stage kinda hard to render for the PC , You have maybe way to make it less rendering time or only if I put less then 4k image or make ither things that make the background less sharp?
    edited June 2023
    Most of the time, you can't have your cake and eat it.. Rendering a 4K image with Iray really takes time if you want it to be clean, with hi-d details etc. But most of the time, it's not necessarily the high resolutions that determine how impressive your render is...
    BTW, yes you're right, you may use a Depth of Field in your render depending on the subject you wanna show ...
    Ohhh I see! Yes I know the 4k make its x2 time then 1920 but I love it you right about the "cake" Hahahaha.
    And thanks for the advice!!!! you help a lot here not only in this post! THANK YOU
    You're welcome and Happy Rendering ! laugh
