How to remove the limit rotation of the lips on power pose?
James
How to remove limit rotation of the lips on power pose?
I wanted to make a lip biting pose.
But there's no good morph for it, and the rotation for lips points are limited on power pose.
Is there a way to unlimit these?
You can turn off ALL limits from the Menu -> Edit -> Figure -> Limits. You can select multiple nodes in the Scene tab to access the individual limits in the Parameters tab through the gear icon at the right side. If you have Consolidate Properties checked, all identically named properties will be grouped together when you select All at the top of the tree, and you can set (or remove) limits on all of the selected nodes at the same time.
